SATA problem
exsquaddie
I have a hardrive running on an IDE cable which is what i have windows 7 operating on and have tried installing a new "Western Digital Caviar SE16 WD3200AAKS SATA 300 320GB Internal Hard Drive" but the problem is that i cant get the drive to show up .... i keep getting ULIraid 5287 initialization error .... ive re installed the SATA raid drivers but it just wont show up on my device manager or bios ? .... any help is very much appreciated :)
P4 3.2GH
ASROCK 775TWINS HDTV mobo
Radeon x1950 pci
set your SATA ports to run in IDE mode. Also, does the new drive show up in the bios?
Since that is a SATA I motherboard you may need to do something special to that SATA II hard drive to get it to work on the motherboard.
Typically you need to jumper together some of the pins on the back of the drive to get it to work correctly.
