Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ok i have been working on my new build and am going to sleeve my psu cables. i have a issue with the sata power connectors. i need the connector to be flipped is it possible.
like the way the p180 mini positions the hdds it makes it so that the cable is the orientation to the drive i would have to twist the cable to put it in. i was curious to see if i could take the connector off the cable and put it on backwards? or is the wire scheme different?
well, you can flip over and then turn it around and that would keep the wires where they need to be. But most PSU connectors I've seen aren't removable.
