SATA Power connectors
Thunder
Im looking at upgrading to SATA II, getting 2 drives, upgrade to for later one. I was wondering if any retailer sells power connectors that go from drive to drive (like right angle connectors, then an inch or so of cable then another connector, another inch, another connector, like I had for IDE. I am talking power connectors, I know I need seperate for the data, I was just curious if they had them for power cabling. TIA,
John
I think so.. When I received my SATA drive about 2 months ago (OEM) In my box-o-parts I found a 4 pin - SATA_power - SATA_power connector.. between the SATA_power to SATA_power was about 1 1/4 inch of cable.. it sticks out a little.. wish it was shorter because my drives are mounted right on top of eachother and it makes a bulge..
