slugger_2003
- Jan 30, 2007
I thought there was a problem with my hard drive so I used this program to test it: http://support.wdc.com/download/?cxml=n&pid=999&swid=3
It returned the result that there were bad sectors. It tried to fix them but an error occured during this process.
I presume this means I need to buy a new hard drive, yes?
My hard drive is a Toshiba MK2035GSS, everywhere I look it appears to be SATA-II but according to DLGDIAG it's an IDE drive. Is it possible the drive has been connected to an IDE port instead of a SATA-II port?
How do I find out what kind of hard drive to replace my current hard drive with?
I'm using vista and can't find the "run" program so I can start dxdiag...
Any comments or suggestions appreciated, thanks.
