SATA on gigabyte 8KNXP
codename47
Hey I was wondering if anyone knew of a setting that I need to change in order to find the SATA drive I'm using on the board.... maybe a better question can I do the following.... run two raptors in raid 0 and hook up a single 160sata drive for storage of the remaining sata ports? There are 4 on the 8KNXP and right now two are taken (one set) for my raptors but I'm struggling to get the other ports to recognize a drive at all? Any hints, suggestions, etc...
make sure that both SATA chips are enabled in bios, then make sure you have the windows drivers installed. hook em up, then before windows starts you should be given instructions on how to configure the drives
