SATA on a KV8 Pro info needed
I'm soon going to put a SATA drive on my KV8 Pro, and I'm a bit confused regarding drivers. I used to run a PATA RAID array on an older board which was no problem - I'd hit F6 on install, then install the RAID driver when XP booted. If I'm running SATA without RAID, do I need to install a driver after XP boots for the first time? I'm assuming I need to install the driver at the F6 prompt, but the manual is a bit unclear about whether I need it for a non-RAID setup in XP itself - it says in the manual to install the SATA RAID driver, but I won't be using RAID.
Lol, I'm kinda having the same problem and am confused about the same thing. Windows wont install on my drive because the drive is not recognized, but on my chaintech nforce3 board it worked fine. I hope somebody comes to our rescue!
If you don't see the drives during install you will need to load a set of drivers. The drivers are loaded the same way as the raid drivers would be but there should also be a set of non-raid drivers that came with the board.
The only three drivers that came with my board are 3 RAID drivers :( I've searched the epox site, got confused by the horrible engrish (You'd think a company would pay a decent translator), and couldn't find any non-RAID sata drivers there either. Anybody know where to find them? the board is an EPoX 9HEAI VIA k8t890 + vt8237r chipset.
The three options I get are SI3112, S3114, and VIA RAID boot floppy.
From what i get from the readme the raid drivers are the only sata drivers. There is also a non-raid BIOS...not sure where that falls in though with the quick look over I gave it. You might try setting the drives up as single arrays on their own if that's an option then just installing the raid drivers. That's kind of what I'm getting from reading the readme.txt file in the drive download on their page.
