Having a problem with a drive... I have a server with a mish-mash of drives (9) one of them being a WD SATA 250GB...
I physicially moved the machine and the SATA drive was unreadable and windows reported the drive as full (it only had 40gb of data on it). I recovered as much data as I could and tried to reformat the drive.
Formats through windows fail (generic unable to format error). I have the acronis disk suite and tried through that... seemed to work ok. Explorer will not report the size of the disk and I get a structure corruption error when I try and access. (I have deleted partions numerous times through windows and acronis, created new ones of difference sizes etc. all with same results)
I tried to perform a chkdsk on the drive and it returned the error "second boot sector unwritable"
Using acronis I deleted the partition and wiped the drive (write 0s), no change.
I AM able to format to FAT32 and the drive does seem to copy data to/from and function ok.
I ran the WD disk check tools from their site both short and extensive both came back ok.
I am as I type running the write 0's function of the same WD software but do not hope for much..
I am at a loss? How can I erase/fix the 2nd boot sector for a NTFS partition as it seems the drive is ok?
I have reseated all cables/controler cards and have reinstalled the controler drivers....
