Jul 16, 2006 #1 R Roman79 [H]ard|Gawd Joined Oct 2, 2000 Messages 1,393 Do they use the same SATA connector as desktops? I was thinking about getting one for my HTPC. Thanks!
Jul 16, 2006 #2 LOCO LAPTOP [H]F Junkie 2FA Joined May 4, 2006 Messages 13,362 yes, if u want to plug the HD to a comp. no, if u want to plug a regular HD on a laptop.
Jul 16, 2006 #3 R Roman79 [H]ard|Gawd Joined Oct 2, 2000 Messages 1,393 Okay now I'm confused......how can it work one way and not the other if it has the same connector? To clarify I want to take a laptop HDD and connect it to a desktop computer via SATA. Thanks.
Jul 16, 2006 #4 swatbat [H]F Junkie Joined Apr 25, 2001 Messages 13,086 The connectors are the same. You can hook a laptop sata drive into a desktop.
