doormat said:I believe SATA-II is supposed to have some sort of hub where you can have multiple drives on one channel. Which would make sense, since I highly doubt you'll have one drive putting out 3Gbit/s.
Jason711 said:what drives come close to 1.5?
doormat said:None. But the expander thing wont work with SATA-I (I believe).
Jason711 said:i didnt believe any would. i guess im just puzzled as to why they made it that way.
Hmm, well, let's see if I can do a better job of explaining it...Jason711 said:break that down retard style.![]()
UICompE02 said:Hmm, well, let's see if I can do a better job of explaining it...
A port multiplexer is something that's used to connect multiple drives to a single SATA port.
In order for the port muliplexer to know which drive it is talking to, the SATA II specification has added a field in the SATA FIS (that is the structure that is used for commands sent to the drives, such as Read or Write, etc.) that tells the port multiplexer which drive to send the command to.
Since only the port multiplexer and controller have to be aware of this field, you will need a SATA II controller to use a port multiplexer, but you will be able to attach SATA I drives to the multiplexer.
Does that make more sense?
doormat said:Any idea when SATA II raid 5 controllers will show up? I want to get a raid 5 controller and the multiplexors and have some huge storage array.
Jason711 said:ok, so you could have more than one connector per sata cable?
