SATA II (300MB/s) PCI-e Only?
jedihobbit
In the process of trying to config (or groping in the dark?!?:eek: ) a file / print server I find myself on the short end of SATA ports stick. The Biostar 6100-939 that I want to use (BluHaz reDux sig) only has 2, so would like to “pick up” a few more. While I have a PCI-e connector, it is unusable because of the Swiftech NB cooler so need to go plain PCI. This shows the fit issue I had with the initial DreamCatcher build…..
Now the “apparent” issue, SATA II (300MB/s) seems to only come in the PCI-e format > is this industry standard and/or limited by the PCI buss? Secondly if I am limited to 150MB/s will it really be that “noticeable” for home usage?
yeah, PCI bus bandwith is the limit.. don't know whether there will be noticable difference between 150 and 300 SATA.. just an idea - you could try cutting a little bit of the PCB to squeeze the card in there.
Just buy a PCI SATA 150 card.
All 300 MB/s SATA drives can operate at 150 MB/s (they usually have a jumper), and in reality the sustained performance of the highest-performance drives is in the 60-70 MB/s range. The PCI card will be limited to about 110MB/s, but that's really not a problem unless you're plainning on running a RAID array.
There are plenty of SATA II PCI cards out there. Newegg has several.
What on Earth are you guys talking about? :confused:
are u crazy! don't cut anything.:p
Not to worry! BTW if you happen to look closely you can see where I had considered “hack sawing” the mounting bracket of the NB cooler! :eek:
Firstly it seems I managed to confuse some people when I included the “example” picture. I’ve actually built two systems based on the Biostar 6100-939 board. The setup I want to use for the server was built first and used the 159 NB cooler (BluHaz reDux). The second build (DreamCatcher) is where I wanted to use the PCI-e SATA card and had planned to use another 159. The picture showing the interference was just a “test fit” using the BH rDx build. On DC I ended up using a NC-U6 cooler and with “applied physics” made the
mounting pin/bracket fit.
Secondly the more I think about it, I’m not elite ;) enough to be able to tell the difference between 150 (133 pci) and 300 for what I plan which is share music, pictures, some video, and text files between 2 – 3 desktops and one lappy. The other function would be to share my two printer and scanner between them. RAID has crossed my mind for back up but again don’t know if I’ll “see” the difference.
Trying to keep the investment down (and not a big fan of green or red psb!) I had considered a http://www.shop4tech.com/item3650.html but then someone showed me this for SATA II http://store.cwc-group.com/sil31242.html and thought having the two e-SATA ports would be nice.
