Sata & Ide
KUJO
can you run both of these on a mobo at the same time? or do they run on the same channel?
also, registered or unbuffered? choices on newegg
why does ddr stop at 400 on mobo if they offer 533?
Of course you can run both at the same time silly
and as for the DDR400 and up
Most motherboards "Officially support" DDR400
most anything will actually work in them
DDR400 is the current speed set by JEDEC for Processors that run a 200MHz FSB. That doesn't mean any other DDR speed wont work though. DDR400+ is overclockers RAM and not purchased by the gerneral public so there is no reason to say the motherboard supports it. If you dont know it supports it then you dont have any business overclocking as a rule of thumb lol.
You only need registered DIMMs in servers for error checking. That one millionth of a chance that you could have a system crash or data corruption on a server is life and death. For us regular desktop and workstation users its not. Registered DIMM's are also slower then unbuffered DIMM's because they have to spend an extra clock cycle checking the memory for errors.
