To preface, I went through a few pages of search results on this topic and didn't quite find what I was looking for.
I work for a company where we encode a lot of large media for random clients. We're looking to get organized with our storage needs for keeping the uncompressed media. In my mind I envision a very simple sata hard drive "drive", akin to a floppy drive. This means you would literally shove a bare SATA drive in a slot and it would plug right in and use the hot swap ability to transfer whatever media you wanted for that particular client and then "eject" (safely remove hardware) the drive and put it into storage.
Does such a device exist, or am I forced to use a hot swap enclosure that makes you mount the hard drive inside a relatively cheap "holders" (I'm not sure what they're called)? Here's a link to what I mean:
http://www.newegg.com/Product/Product.asp?Item=N82E16817121405
I assume the reason I cannot find a device that accepts bare drives is because the exterior of hard drives varies too much for it to work consistently.
Thanks in advance!
Thanks in advance!
