So here's the storage setup I will be using after my new shipment of drives arrive:
2*750GB Samsung F1s in RAID0 Set up into two two partitions-an OS one, and a Media one (just for easy organization). I will be using this RAID array to do most of my photo work/storing my music
1*1TB F1--I will be periodically backing up my OS/Photos/Music onto this drive
2* 750GB Drives to backup my movies (ISOs are SOO much easier to deal with than searching for physical discs...although the "Wow" effect is dramatically reduced. I will be using these only when I wish to watch a movie, which is why I want to install a SATA rack in one of my 5.25" bays, so they get less wear and whatnot.
So, I've got a few questions:
1. Anything blatantly wrong with my setup that I should consider?
2. I'm going to hold off on SSDs until they get a bit cheaper/better firmware/better controllers, and will move to a RAID0 array of those guys as well. (yes, I know, it's not a question, but some people might be "hey, get some SSDs if you want more performance)
3. What kind of SATA racks would you guys recommend? I'm looking to spend as little as possible, as I currently have an eSATA dock (which actually bugs up on me ALL the time when using eSATA, so it's now a sluggish USB little guy) that I could deal with, but I greatly prefer SATA speeds.
4. Tray-less or tray-type of rack? I kinda don't want to spend an extra $25-$30 on trays along, especially when I have a padded sock drawer I stash my drives in when I'm not suing them.
5. Any features I should look for? I thought one with a power switch would be nice--to easily turn off the drive before removing it. (yes, I'm a terrible person for not using "safely remove hardware"
6. Anywhere cheaper than Newegg? Newegg has an iffy $20 model with free shipping.
7. Oh, and I'm looking for a single 5.25: bay, btw.
8. Any advice on power requirements? I saw some models have both molex/SATA--does the Molex power some sort of controller chip? I would prefer just a SATA/Molex power plug, as some models also have a little 4-pin plug that buds off of the SATA power. Also makes wire management a LOT easier...
Thanks in advance for some good advice!
