Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
the bizzare thing is that it only happens sometimes for me. had to reinstall windows twice recently, and the first time i got one of those 2 second formats, the second time it was more normal. both times the drive already had data on it.
if it takes 2 seconds for 40 gigs it's probably a quick format, i've formated my raptors twice as well as a 250 gig wd sata drive, teh raptors took about 30 minutes or so for a full format(74 gig) and the wd took close to an hour.
No, it wasn't a quick format, at least quick wasn't selected, the drive may be doing so of it's own accord but it was most definetely a full format that was selected.
Dano.
Well, I am talking about a format during XP installation which is using DOS at that point right?
I'll try a proper DOS format sometime but right now I have data all over so no chance
Dano.
