dolphumous said:Get a PATA to SATA adapter for $10 (Abit Serillel that came with the NF7-S for example) and use it with whatever drive you want.
That's all Plextor is doing anyway. There are no native SATA burners out there. You'll notice the plextor drives are over an inch longer than normal drives...it's the adapter on the back.
dolphumous said:I still didn't think they're native sata. I thought it was just a revised adapter.
Either way a NEC ND-3550a and a SATA adapter is $45ish...which is a much better deal than Plextors $analrape.
