Oct 2, 2010 #1 H hellosky Weaksauce Joined Mar 28, 2010 Messages 111 Looking into buying a refurb Dell server - is it OK to buy a system with only SAS drives and then stick SATA drives into it? In another words, do SAS backplanes take SATA drives? Are the SAS and SATA connectors identical in shape and size?
Oct 2, 2010 #2 B Blue Fox [H]F Junkie Joined Jun 9, 2004 Messages 11,813 SAS backplanes will support SATA drives. The connectors are similar, but not identical (can't put SAS drives in a SATA backplane).
Oct 3, 2010 #3 H hellosky Weaksauce Joined Mar 28, 2010 Messages 111 Is this because SAS drives do not have the gap in the middle like SATA drives do? So if I understand this straight... SATA drives can fit into SAS backplanes SAS drives cannot fit into SAS backplanes (because of the gap with the power/data connectors) Thanks!
Oct 3, 2010 #4 B Blue Fox [H]F Junkie Joined Jun 9, 2004 Messages 11,813 That would be correct. The extra bit not present on SATA drives also holds the second set of contacts that is used in dual port drives.
