1. Literally ALL consumer-level desktop drives for the last several years have been 7200 RPM. That's not really an issue, and the platter speed actually has little to do with it anymore (look at the WD Raptors, which at 10k RPM, have little performance gains for the reason I'm going to discuss below).
2. There is a speed difference between SATA (both I and II) and IDE, which comes from them being different protocols. IDE is a parallel interface, which like PCI and old-style parallel (printer) interfaces, is slower than the newer Serial standards. IDE gives at max 133 MB/s (about 1 Gbit/s) of transfer bandwidth. SATA I (the older SATA standard, of which, for instance, Raptor is a member) offers 1.5 Gbit/s and SATA II (the newest standard; almost all new SATA drives are SATA II) offers 3.0 Gbit/s, almost 3x the theoretical transfer speed of PATA.
Now, the biggest hurdle in hard drives today is seek time, which is usually the same for identical models independent of the connection. Also, cache can help increase performance.
Actually, there is almost no difference in a single drive configuration between sata and eide performance wise except the often nearly meaningless "burst" benchmark. Just what the hell are you bursting from cache anyway? And the fact that it takes the IDE drive 1/3 of a second to burst what tiny little is there as opposed 1/20 of a second for sata. Supposing that both drives are essentially identical except for the interface of course. Modern eide 133 drives are barely, if at all, slower when it comes to sequential reads/writes than sata drives are. Not really noticeable. Going from a 500gig seagate eide to the otherwise identical sata version would be hardly noticeable.
EIDE drives can loose performance, in some situations, when there are two drives on the same cable, (large read from one drive and write to the other on the same cable will be slower than drives on separate channels for instance).
The change to sata came about for reasons not wholly focused on performance. Possibility for very high speed external connections(e-sata), smaller cheaper connectors, thinner cheaper cables, less complicated (cheaper) circuit patterns on mobos and controller cards. While at the same time increasing the data rate far, far beyond anything the drives themselves can actually use, or the pci bus many controllers sit on can even transfer, currently (great for marketing).
SATA is better imho, but it is still not that much faster right now than eide 133 given a typical single drive config with a modern drive.
OP: if your WD is a modern eide/ata133 drive you will see virtually no improvement speed wise by switching to a 250gig WD sata drive.
When I got my new 500 gig 7200.11 a couple of months ago, it came configured for SATA 1 for compatibility reasons. I ran HDTune on it, and the burst speed was slightly faster than the peak sequential speed at around 105 MB/SEC. When I pulled the jumper to allow SATA II operation on my drive, the burst speed jumped to almost 190 MB/SEC.
Since Sata 1 is supposed to be 150 MB/SEC, and ATA133 is supposed to be 133 MB/SEC, we are finally seeing drives that can swamp the EIDE channel. And, by definition, SATA 1 is also nearing obsolescence, since it is only a bit faster than ATA133. Sata 1 was limiting my drive in real world performance to "ONLY" 105 MB/sec
Now, 100 MB/sec is still pretty good speed for current hard drives. If you already own the PATA drive, the performance increase to going to a SATA II drive in real life uses would be minimal. Not hardly worth the cost to upgrade.
When building a new rig, only buy a SATA II drive, period. A lot of the newer MOBOs only have 1 IDE channel. There is finally a good number of Sata optical drives out there, and they don't cost any more than the IDE models. I think the IDE channel will go away in another year or 2.
Don
Agreed. I also wonder how many people are unknowingly running in IDE emulation mode anyway. If you didn't load AHCI or RAID drivers, then your drive will be running emulated IDE, so no speed increase for you. Not that it would make much difference, as has already been stated. My first 7200 rpm drive was 4GB. I'm willing to bet my current drives will read 4GB much faster than the 4GB drive could have transferred the entire drive. Platter density is much more important than spindle speed. I'm sure a lot of the reason for the interface change was to force people to have to buy a new hard drive with that motherboard upgrade. And it will happen again.
If they really wanted you to buy a new hard drive, why would "THEY" allow the MOBO manufacturers to continue to put IDE connectors on MOBOs?
Ok, take off the aluminum foil hats for a second.
Sata was developed because it was becoming increasingly difficult to increase the speed of the parallel architecture of the IDE bus. It is the same reason they went from the parallel AGP bus to the serial based PCI Express bus. It is easier to scale up the speed of a serial connection. You do not have to synch all of the data lanes.
The only failure I see in SATA was not wiring in a few more data paths for future expansion in the original spec. While todays drives are just beginning to max out IDE 133 and Sata I, who knows what will be available in 10 or 20 years.
Ok, you can put your foil hats back on.
Don
sata's interface is a big advance.
Agreed.
I'm almost tempted to go out and buy a freakin' Sata DVD writer. My current IDE drive is perfectly fine but having this large and cumbersome cable traveling down my case is a little annoying. :/
If you want better performance and you've got alot money to throw around, go SCSI. Nothing says fantastic like SCSI drives. Unlike IDE and SATA, SCSI can read and write at the same time. Plus, all SCSI drives are 15k RPM so they'll have fast timings. The bad thing is they are crazy expensive and are mostly used in corporate servers.
I came to this threading hoping someone had pointed this out.Actually, there is almost no difference in a single drive configuration between sata and eide performance wise except the often nearly meaningless "burst" benchmark. Just what the hell are you bursting from cache anyway? And the fact that it takes the IDE drive 1/3 of a second to burst what tiny little is there as opposed 1/20 of a second for sata. Supposing that both drives are essentially identical except for the interface of course. Modern eide 133 drives are barely, if at all, slower when it comes to sequential reads/writes than sata drives are. Not really noticeable. Going from a 500gig seagate eide to the otherwise identical sata version would be hardly noticeable.
Don
