Ok, as the subject said, I'm in major need of some help on this one....
Here's the situation and the details.
MB: Asus A7N8X Deluxe (rev 2.0)
Proc: Athlon XP 2500
Mem: 1 gig
Vid: 9500
I had a raid set previously made up of 2 Maxtor 250 gig drives, that were
actually IDE, but had adapters to make them work as SATA. After one of the
controllers, started to flake out (not always recognizing), I decided to ditch the
RAID 0 array, and flip in a single large HD.
I bought a Segate 750 gig HD, SATA II, and an external SATA->USB2 enclosure. Attached the drive via USB, to copy my data over, and all was good.
Now when I tried to attach the drive to the SATA channel on my MB, it hangs after it identifies the drive on the primary channel. I also tried swapping channels, and had no difference. Yes, I tried different power legs, different cables, pretty much everything that was swapable, I swapped.
The main BIOS screen pops up, passes normally, Then the SATA bios comes up, identifies itself, acknowledges the drive, and then doesn't move past. I've tried hitting both F4 and CRTL+S to go into the RAID configuration of the controller, but it wouldn't budge. No response from the system at that point.
Thinking that something may be wrong with the controller, I tried disablig it via the jumper, and added in a PCI SATA card, and had the exact same result.
It is technically a SATA II drive, but I've got the jumper set to 150mbs so it hopefully shouldn't have a problem. I've also tried it at the native 300mbs setting with the same results.
Now, here is the part where it gets really weird!
If I boot the computer, without the drive attached, everything works fine. If I then plug the drive in hot, it pops up, and works perfectly fine. So I know that both the addin card, and the onboard SATA controllers are functioning. For some reason they are just choking moving past the drive at boot time.
My boot drive is the master disk on the primary IDE channel, so I'm not looking for this to do anything but storage, and maybe be a home for some extra software.
Onboard SATA controller is a Silicon Image 3112A
PCI SATA controller is a Silicon Image 3512
I've flashed BIOS on both of them to the latest, and haven't had
any change in results.
I've also tried asking everybody I knew locally, and got the largest amount of quizical looks and scratching heads I've ever seen in my life.
I throw myself on the mercy of the [H]ardforum. Please help me, I'm totally stuck!
Thanks
-Jeff
Mem: 1 gig
Vid: 9500
Thanks
-Jeff
