Hello, I just put together a new system and didnt have any issues. Played all night with it....then the windows auto update ran. After reboot of the update, my system sits on the windows screen for a while. *Also my sata drive (main boot drive) is now showing up as a removable device in the task bar. edit( did some searches and this appears to be fine)..however since that update I am still getting these ide paging errors.
I checked the device manager and all the nvidia devices appear to be installed and working fine. I have a few listed under the IDE ata/atapi controllers: nforce parallel ata controller, nforce serail ata controller.
After windows finally loads, the event viewer has error detected on device during paging operation. I ran maxtor diagnostics on my sata drive and 0 errors found. I reformatted the drive and put it into my other box which is an older n3 board and everything boots wonderfully. Then went through another hour of reformatting and installing back on my new n4 A8N board and wham! Boot times out the ass again along with the event viewer error.
I have an Asus A8N5X
Maxtor Sata drive
4400x2
7900gtx evga
ocz 2,3,2,5 matched pairs
lite-on dvd player
(As of right now, these are the only things I have hooked up)
Thanks Drep
Maxtor Sata drive
4400x2
7900gtx evga
lite-on dvd player
Thanks Drep
