Silent Assasin
- Aug 1, 2004
Ok, so I've got a WD200GB SATA drive that's I've had for several months now. About a week ago, I turned on my computer and just after windows finished loading, usually where my logon screen comes up, Windows goes into CHSDSK and scans my E:/ drive (sata) for errors. This is after a week of not being used, and I know that last time before that, it was shut down properly. Well I don't worry bout it too much. Everything works fine for several days, but in this time the computer isn't shut down. I tend to leave it on for several days at a time then occasionally shut it down over night. So anyway, next time I boot it up, same thing happens, I let it go. Then when I start playin World of Warcraft, I get the blue screen of death but there is no error message, just a blue background on my main monitor and not even a signal on my second monitor. I reboot..... Now durring the POST, it hangs on the IDE detection and sits there untill I reboot or power down. It won't even let me into the boot sequance in the bios to let me choose where I want to boot from. All this happens before my floppy drive boots as well, so my Lifegaurd data recovery boot disk does nothing. Finally I powered down, unplugged sata drive and everything works fine. I do a virus scan, adware scan, etc. Norton picks up a trojan in javascript. I quarentine and delete it, but that didn't help anything.
Anyone have any ideas what's going on? Or I've also heard that sata drives are built to be able to "Hot swap" them while the computer is already booted. Does anyone know in which order I should plug in the cables though, power first or second? I was wondering if my sata drive will boot after Windows is already booted......
