SATA drive assigned wrong drive letter.
Tilde84
As my title says I recently upgraded my hard drive and installed a new copy of XP on it. After completing the installation I noticed that in My Computer the Local Disc is labeled E: everything works as normal, but my problem is that when opening certain programs I get an error message that says to insert a disk and try again. I think this is because my floppy drive is labeled A: an those programs giving me errors are trying to load from the A: drive.Does this sound right. also how this this happen and is there any work around or way to change this? Thanks.
Traditionally drives are:
A: 1st floppy drive
B: 2nd floppy drive
C: 1st drive on Ide/sata channel 1
D 2nd drive on "/ " " 2
E: Usually the cdrom if "d" is enabled
And things can change depending on how you configure your system.
you can go into disk management and re-assign drive letters.
I tried that, but when I hit the change button on my single SATA drive I got an error saying "Windows cannot modify the drive letter". Would simply switching the SATA cable on my mobo to another port change the setup at all?
Detach your other devices, reinstall XP as an upgrade/repair, power down, reattach your devices, reboot. That should do the trick without trashing your HDD.
