Ok, so I've been dealing with my MBs slowly dying ata controller since I bought my computer over 2 years ago.. (maybe more... I don't remember exactly - around when the 7800 gtx came out)
First my hard drives wouldn't always show up at boot. Then occasionally I'd get corrupted files, and now I cant even install an OS. My linux install now fails out with ATA errors and "input/output" errors during boot.
I've changed out 3 hard drives, swapped out a new GPU, pulled my other pci cards (linksys wireless and xFi), installed a new PSU (when I upgraded to my GTX 280), changed the ram (both sets have been tested return no errors on another box I have), and I have reseated every last thing enough times that I'm sure the pins are wearing down due to friction! j/k
So at this point I'm convinced that the motherboard - specifically the onboard ata controller - is frakked.
So heres the deal: I'm a starving college student. At best I'll be able to scrape together around $200 to MAYBE $250 to fix this problem. However, I want to get this machine up and running asap and the cheaper I can make it, the quicker I can order my parts.
What I have:
AMD 939 x2 4200+
ASUS A8N-SLi Premium
2GB DDR ram
NVIDIA GeForce GTX 280
I'm happy with my computer's speed - it takes just about everything I throw at it. I used to play wow windowed with a dvd or video playing in the bottom corner. Sometimes I'll do some 3d rendering, and subsequently video encoding - so performance is a plus.
I'd LOVE to be able to replace my motherboard - as I believe this is going to be the cheapest option, but I know that at this point buying a 939 motherboard is somewhat pointless and I might as well upgrade.
So heres what I need:
Advice as to what I can get for a bit of an upgrade. I need MB/CPU/RAM to come in as cheap as possible, and net me performance at LEAST as good as what I had. I'd prefer something to bring my system closer to my GTX 280 - but whatever I get needs to be around $200.
What I have:
AMD 939 x2 4200+
2GB DDR ram
