I have 6 SATA connectors on my motherboard. They are located in the lower right hand corner, running perpendicular to the case bottom. I just purchased a video card, which it's length causes an overlap of SATA 1 and SATA 2.
Is there any issue with dropping my current 3 connections (sata 1-3), down to the bottom 3 (sata 4-6)? Is there any options which need to be changed, or will there be no issue?
