SATA Combo Drives?
Is there a benefit to having it in sata interface?
Faster overall limit 1.5 or 3.0
less CPU overhead
better cabling
TCQ and NCQ
the fact that all new drives are SATA makes it better i guess.. since if you want a nice new 16mb cache large HDD, your chances of finding it in EIDE is pretty limited
hmm thats all I got...
less CPU overhead
better cabling
TCQ and NCQ
They make "combo" HDD's now?? Which ones? What is the "combo" option on em?
I think that the OP meant "Optical combo" drives. Basically the better cabling and the bragging factor of having a SATA cd/dvd-rom drive.
All I can say is I'm definitely going all SATA on my next PC, I'm not going to have a single ribbon cable at all. Ribbon cables = poop, especially when they have to stretch from damn near the bottom of your case to damn near the top :mad:
You do know that they make rounded IDE cables now?
Yeah, but aside from the actual cable, the wide connectors are annoying as well, especially if space is tight. Sometimes they're super-secure, too. I bet some people have broken stuff inside their case trying to pull them out. :D
I've cut myself plenty of times pulling really hard on the connectors and recoiling across the edge of my video card.
I would personally have all SATA interfaces and nothing EIDE simply because EIDE cables are more of a pain to mess with. They're harder to hide and harder to plug and unplug. There are also some slight performance benefits to the SATA interface as well. I would check CDFreaks forum for info on that and the best SATA drive. I don't know what SATA combo drive you're looking at but you might as well just get a DVD+RW. It's not like they're very expensive. You can get one for $30-$40 at Newegg.
