they ought to, but it is hard to know what manufacturers do.Are all SATA cables about created equal?
quite likely.I have a bunch of SATA cables I have used for my SATA 1 drives would they be capable of the 3.0 Gb/s speeds as well?
However, some cables have a special clip to make them more securely attached to the drive. I haven't needed to use these in the past, but it's something to consider if you have problems with cables falling off.
I very easily broke a sata connector on my seagate. It seemed to me the plastic was very brittle and easily snapped off. .
