PCTechGirl
- Feb 24, 2008
Forgive me if this is a dumb question, but what exactly is the difference between a left-to-right and a right-to-right angle SATA cable?
I have an Abit IP35 Pro mobo whose SATA ports are on the edge of the board facing sideways. For cable managment purposes, I was going to cut a hole in my case's mobo tray right at this part so I could use angled SATA cables.
The problem is, I purchased a SATA cable with two 90 deg connectors, and nothing lined up. I was hoping that the left-to-right might be the answer, but wanted to make sure before I ordered anything else.
