SATA cable questions.
2004raptor
The SATA power cables that came with my power supply are very stiff. The problem is the way my SSD mounts into it's bracket places it close to the bottom of the plate. And the SATA power cable is so stiff that it goes in at an angle and seems to pull up on the actual SSD connection. This seems like it causes undo stress on the connector.
Does anyone sell SATA powr connectors that are more flexible?
Looking around on google I do see some aftermarket ones but all of the say SATA II. My SSD is plugged into the SATA III port. I can't imagine there would be any issue but I figured i would ask.
It does not make a difference.
The UltraFlex cables from SATACables are about as flexible as a piece of gum.
I purchase the yellow 13" straight to right angle cables that always fit great for my computers.
