SATA Cable question
runt
ok, i just rebuilt my computer using SATA cables (and SATA to PATA adapters for now) and i am in need of shorter SATA cables. i have 18" cables right now and they are way to long. where is a good place to go to get shorter ones?
for some reason the shortest ones i have seen are 18 inches, they would make 10 inch ones, the cable jsut curl up in the case
thanks for your help guys, i will probably order from frozencpu when they have the blue 6" ones in stock
