Hi all...
I got an Compaq Presario SR5223WM from a friend, whose power supply went on it.
Gave it to me so that I can fix, clean and resell it.
Installed spare power supply and it works fine. Used Compaq's restore application to get it back to default, as if from factory.
This computer had a 120 some odd SATA drive in it. I had a spare IDE drive laying around and threw it in there. When I have the IDE drive installed, I have to use a boot menu to boot off the Vista SATA drive. Otherwise, it tries to boot off IDE and doesn't boot because the IDE is a scratched/formatted drive. In the BIOS, I see both drives. The IDE (slave) is set at the highest or first boot drive. I cannot use (+) to move the SATA up so that it boots from it.
I know I'm doing something stupidly wrong with too much vodka in my system to realize it... any I ideas?
