k so im running a new comp, heres the specs:
p4p800-e delux
saphire 9600 256mb
p4 3.0e
512 kingston
maxtor 80gb 8mb buffer SATA (x2)
so i install xp running normal sata no issues, but when i try to set it up running raid 0, it goes through the xp install, and no matter what sata and raid driver i use, the install says it cannot detect any hard discs when xp normally gets to the part where you choose the drive your installing onto.
i setup raid on the bios according to the instructions that came with the mobo, and have everything pluged in correctly, the 2 drives were setup as one raid0 drive, everything shows correctly in the bios and the raid configuration.
ive tried every sata and raid driver on the cd that came with the mobo, and a few off the net, but they all give the same problem, me and a couple of my friends are pretty sure that i just dont have the right driver, but were not sure exatley.
can anyone tell me what im doing wrong?
p4p800-e delux
saphire 9600 256mb
p4 3.0e
512 kingston
