Hey got a problem when I boot and it's checking the promise chip on the Maxtor Sata / 150 PCI Card (it says NO BIOS LOADED) it use to work with no problems ,everything in
my DFI mobo is set correctly ? The sata card is hooked to a Maxtor 6L300RO 300gb .
I think the card went bad on me ,also ( It's drivers are always loaded correctly off the floppy) whenever I re-format .Do you think that pci card went bad.I connected the drive up
to my slave ata ,and all was fine with the H/D ...Thanx
