meinzorn said:will a sata 3 drive work in a board that supports sata 1.5??
That shouldn't be necessary except in very specific cases. The SATA protocol will automatically negotiate to the highest commonly supported speed between the two devices. (of course, there are bugs out there in some chips that cause problems with this and that's why the jumper exists on some drives)tuskenraider said:And if the controller is SATA1 and the drive SATA3, make sure you jumper the drive so it will operate properly.
UICompE02 said:That shouldn't be necessary except in very specific cases. The SATA protocol will automatically negotiate to the highest commonly supported speed between the two devices. (of course, there are bugs out there in some chips that cause problems with this and that's why the jumper exists on some drives)
