Sata-0 detected, everything else not?
Status
Not open for further replies.
RoffleCopter
I just bought a new hdd (WD6401AALS) and as I was installing, I noticed that the BIOS would detect whatever was on sata-0, whether it be the new or old drive. If I plug any of the hard drives into sata 1,2, and 3, the drive is not detected by the BIOS. The power and sata cables work fine.
How can I get the bios to detect the new drive on sata ports 1, 2 or 3?
Thanks in advance.
Are there "disable sata" options in the BIOS? Is there an "enhanced" setting for the SATA controller? Have other drives worked in the past?
Ahh, I got it. For some reason, the first time I set sata-1 to "on", the bios wouldn't detect the drive, and after I did it again, it worked...wierd.
Anyway, thanks a lot for the help :p
Status
