SAS?
Discussion in 'Virtualized Computing' started by Forealz, Apr 6, 2012.
  1. Forealz
    Forealz Limp Gawd
    253
    May 7, 2007
    I'm looking to make a little VMware testing station and was looking at hard drives. Because it's just a test machine, I'm not really looking into RAID. I should pretty much just get a SAS drive right? At some point I might transfer an image off it, and I shouldn't run into any problems dropping it on a RAID machine right?
    Looking at newegg, SAS 6gb/s seems to be the right choice, right?
  2. 4saken
    4saken [H]ardForum Junkie
    12,128
    Sep 14, 2004
    just use SATA if its a test machine. You dont really need SAS unless you are dropping cash on a server.
    honestly tho, need more info.
  3. extide
    extide 2[H]4U
    3,183
    Dec 19, 2008
    Yeah why do you think you need sas?
  4. ND40oz
    ND40oz [H]ardForum Junkie
    11,204
    Jul 31, 2005
    I'd go with a single SSD over SAS for testing, IOPS are what you're looking for.
  5. Forealz
    Forealz Limp Gawd
    253
    May 7, 2007
    I was looking into my options. I'd like to have one handy so if I take over administration for a small business server I can use it as a temporary virtual server for them while I either virtualize their server or make them a new vm. So, a small office might run off it for a short period of time, but really only if I run into issues virtualizing their server.
