- Feb 8, 2005
Just how interoperable are these two?
I've heard that you can stick a SATA drive on a SAS controller, but how close are the specs? Like, you know the SATA hot-swap enclosures? Can you stick a SAS drive in there? Can you use a SAS card to connect to the SATA enclosure?
*blinks*
Would it be possible to have a 5 bay SATA enclosure with 2 SAS drives and 3 SATA drives, if it's connected to a SAS controller card? Would it limit the drives to SATA speeds?
With the SAS controllers costing about the same as the SATA controller cards these days ($300 or so for an 8-port card) is there any reason to NOT buy one?
Oh, and does anyone have any links with more info on SAS? I'd appreciate it muchly.
*blinks*
