SAS Motherboard VS SAS Controller Card
no_control
My MSS with it's Sans Digital TR4M sidekick is starting to get full. So I either need to swap out the !TB drives for @TB drives or I need MOAR!!!
So in researching my new WHS build I had submitted to the fact that I would need to shell out a few hundred bucks for the supermicro AOC-SASLP-MV8 cards along with a suitable motherboard.
Then I came across a mobo with SAS on the board Asus P5BV/SAS Seems like a good deal for a WHS in a norco 4220 no? Am I wrong in assuming this board supports 24 drives (8 sata / 4 per SAS x 4)
Looking for any reason this is a less expensive route than say a 775 mobo and 2 of the SM cards above.
I'm not looking to raid or anything like that just straight up WHS file server/ Pc backup
It only has 12 ports
Those are not multilane SAS ports.
So you would need that plus an AOC SASLP-mv8
I've got the aforementioned mobo in my WHS, and I have to say that it has worked beautifully for me. I originally intended on 2 SAT2-MV8 cards in the PCI-X slot, but I found a deal on a PCI-X Intel Quad NIC that I just couldn't pass up. I've only got 16 of the 20 hot-swaps in my Norco hooked up ATM, 8 on the onboard LSI1068E chip and 8 on a SAT2-MV8 card. I plan on getting a SASLP-MV8 or a second SAT2-MV8 card and running it in a PCI slot. I'll cross that bridge when I get there.
In short, that mobo has been great for me.
makes me sad that i have a norco 4020 and not a 4220...
but this thing is soooo heavy there is not way I could ever sell it for a major loss
Don't be sad, breakout cables can't be any more expensive than straight-through multi-lane connectors.
