- Aug 4, 2004
OK, stupid question here but I'm going to ask anyways.
I have a Supermicro X8ST3-F motherboard with a built in LSI1068E SAS controller. The ports that connect to this look like standard SATA ports though. I also have 4 SAS 300GB 10K drives pulled from some old Dell PE 2950 servers that I would like to pass through to my OI VM as a stripped/mirrored pool for ESXi storage (should give me better performance and space than the 4 160GB laptop 7200RPM drives I'm running in the same config right now).
Can I use standard SATA cables and power to connect these drives? Or do I need some sort of special cable to go from the SATA connector type to the SAS connection on the back of the drive?
The other question is can I mix the four SAS drives with the 4 SATA WD Green drives I have in a RAIDZ config for media storage on the same controller? I plan on purchasing a M1015 controller to seperate them before moving all my data to it, but want to run some test/benchmarks against them first...
