kevinchristian15
- Jul 24, 2017
Hi all,
I'm looking to upgrade my old home server (built circa 2008), for two reasons:
1) Support for larger HDDs >4TBs
2) Improved processing power for PLEX transcoding that runs on the server
As the title suggests, my main question right now is on the SAS controller. Most of the threads I've seen are older and reference the same cards IBM M1015/1115, LSI 9211/9240/9260, Supermicro SAS2LP-MV8, etc. Has not much changed in the past 8-10 years or is it that my requirements are so low it doesn't really matter? I don't need RAID, and this is a home environment so cache seems to be an unnecessary expense. Really I want something that supports 16 drives on my Norco backplanes (so likely 2 cards), works with larger drives so I can upgrade in-place, and doesn't have bandwidth/throttling issues.
Ultimately I'll be replacing the core components on the server...current specs are below if you're interested. I'm pretty much starting from scratch so any thoughts you have are welcome. It's been a long time since I researched all this so my knowledge is a bit dated.
Thanks in advance!
Current Rig:
OS: WHS 2011 (reuse)
Case: Norco RPC 4220 (reuse)
HDDs: 20 drives of varying sizes, with one SSD for the OS (reuse)
Motherboard: ASUS P5BV-M (replace)
Processor: Intel Core 2 Duo (replace)
RAM: 8GB (replace)
PSU: 650W Antec Earthwatts (replace)
SAS Card: 2x Supermicro SASLP-MV8 w/SFF 8087 connectors to the Norco backplanes (replace?)
Thanks in advance!
Current Rig:
RAM: 8GB (replace)
