kharan5876
- Oct 3, 2007
So I am building a file server. I am now thinking of using the cheap norco case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811219021
The motherboard is going to be inside of the case as well.
I basicly have 2 options for connecting the disks. I can use SATA or SAS
SATA:
The mobo I have has 6 onboard ports and 2 pci-x slots so I could get 2 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815121009
Total Cost $200
SAS:
I already have a pci-e x8 LSI SAS card
I could get this:
http://usa.chenbro.com/corporatesite/products_accessory_detail.php?serno=943
and then add the cost of cables.
Total Cost: $500-$600
What would you guys do? Obviously the SATA way is much cheaper and probably a lot smarter. SAS would give me the option of adding more of these cases externally if I ever need more disks. SAS might also give better performance?
SATA:
Total Cost $200
SAS:
I could get this:
