The short story is that I got a 3Ware 9650SE-4LPM RAID card (thanks kubebot) connected through an Adaptec 2231700-R mini SAS x4 (SFF-8087) to x4 (SFF-8484) cable to a SuperMicro CSE-M14T-B with 3 SAS 2.5 SAS drives. One of the 2.5 inch SAS drives is a MBD2300RC another is a HUC103030CSS600 and the last one is a ST9300603SS(if this helps). I removed them off of the IBM tray (these drives were for an IBM server but never got used lucky me
), attached them to the SuperMicro trays and put them in the rack. The first time I turn the computer on I hear a continuous beep and the red fan fault lite on. I checked the manual to disable the fan and plugged the rack back in to the power and SAS cable. I didnt notice if this happened the first time but when the computer turns on the rack only shows drive 0 with activity (green lite) for one second. Ive email SuperMicro this morning but they havent responded to me yet (its the 4th/weekend - I understand). Let me know of any of you have any suggestions to help me get past this.
Things Ive tried:
1. Plugging the rack in to a different PSU. I tried a 300w 350w and a 500w and get the same drive 0 green led.
2. Switching the hard drives to a different spot and even one hard drive in every other spot.
3. Booting into the RAID card and scanning for the drives.
4. Clearing the buzzer reset.
Things I know/tried:
1. I plugged the 3ware RAID card into a Dell desktop and copied some files to two SATA hard drive though the card using the included cable.
2. I have the 3ware Raid card plugged in to a P5Q Turbo and able to get into the 3ware BIOS.
3. I got the rack and the cable form newegg and the raid card from kubebot(not implying that this has anything to do with a faulty card).
4. The drives are made for an IBM server. Is there some proprietary command/connection that an IBM server does to find/wake the drives?
5. I dont have another server to test the SAS drives otherwise I would.
Thanks for the help.
Things Ive tried:
