Sapphire Z77 ITX shown at Computex
vipz
http://www.techpowerup.com/167342/S...-Pure-Platinum-Z77i-Mini-ITX-Motherboard.html
According to TPU it has bluetooth onboard. There is also an mPCIe or mSATA slot shown in the picture. Interestingly, it appears to be pointing away from the board.
That Msata is definitely not pointing away from the board, but having it there definitely makes it more accessible than if it were in the center or on the back like the asrock.
Oh, you're right. I just noticed the two screw posts.
looks ok. Probably will be cheaper than the asrock itx, b/c this one does not come with a WiFi card.
