Sapphire X850XT windows 64bit compatible?
shiek
Hey guys,
I just ordered a sapphire x850xt and im going to install it into a amd64 system with windows 64. Now i just read in the windows file that this card has to also be 64 bit compatible... is this correct? how do i find out if this card is 64 bit compatible? or did i just interpret wrong? help me out please :confused: :confused:
edit: title
The card will work great, just as good as in WinXP 32-Bit. As time passes and drivers are improved for 64-Bit, performance may improve as well.
You should see zero issues.
