sapphire trixx quit working
DJ_007
So i recently did a fresh install of windows 7 pro 64bit... I have an HD6950 with shaders unlocked and i just installed a little HD5450 in my second PCIE slot for my second two monitors.. I have ran an old nvidia 6800gt before like this and not had any problems other than the nvidia card running out of vram from aero effects... anyways since i have done this when i open sapphire trixx and go the overclock tab i have no numbers and no moveable sliders... Is it not possible to overclock one AMD card while another is installed?? im really confused by this?
I had issues with trixx even just trying to OC a 6970/6950 in the same box. It would screw the clocks up all the time, not apply fan settings but on one card, and other random goofy stuff. Anyways, to the point, does trixx even support the 5000 series cards? Have you tried afterburner to see if it's any better?
yeah i tried afterburner and same thing... i dont care about overclocking the 5 series card just my 6950.. trixx always work for me before when i had an nvidia card in my second slot..
