Awesome, I just picked up this card for my dads new build. I need to try to unlock the shaders![]()
I picked it up last week on NewEgg. I didn't get a chance to read the entire review, but that's far easier than flashing the BIOS on my MSI 6950s![]()
If you would actually read the review, you would see that all of our apples-to-apples tests were, and always are, done at 1920x1200 4X AA.
Okay cool, and above all congrats on getting such a great card. If you can, please start a thread with pics to show off the card and to give your impressions on the card and it's build quality. I know it's for your father but I'm sure the community would appreciate the thread. Also if you can get the newer bios the review mentioned fixes the throttling issue flashed on the card or confirm it came on their backed up I would be interested if you were willing to share that file with me. PM me.
MY question was , why use a overclocked golden apple vs a regular apple?
And I feel as though it should have been mentioned that a gtx570 at the same price overclocked will give you the same results, without the (not garaunteed) unlock.
This is where you went astray. (underlined)
On this product the bios switch guarantees the unlock. It comes from the factory with a tested and working 2nd bios setting which has the 1536 shaders unlocked. You could say the overclock isn't guaranteed and that would be true.
I agree with your stance that overclocked should be compared vs overclocked IF the reviewer manually overclocks one card for it to be a fair apples vs apples test.
I think you have been reading too many canned benchmark anandtech reviews because the 6970 or in other words a 1536 shader Cayman Pro GPU at 6970 speeds can beat a GTX 570 in real world performance tests most of the time except for nvidia biased games whether at 2560x1600 or 1920x1080
I think that's what everyone is saying here.
I'm so pissed. I was depending on the auto-notify feature to alert me. I was at my computer during that time too. ARGGGH
I just flipped the switch on my Toxic 6950 and it did not unlock or change anything. Do I have to flash a BIOS over? If so, where can I download the BIOS from? I had to flip the switch and flash my MSI ref 6950s, but all I did was download the BIOS off the cards with RBE and change the amount of shaders.
Hmm, one of the BIOS settings should have all of the shaders unlocked. Might want to contact Sapphire if it doesn't.
That feature has never worked for me on a hot item. Have to constantly refresh.
So some testing:
Flipped switched to the left: GPU-Z shows 1408 shaders, BIOS in RBE shows the 6950 shaders box checked.
Flipped the switch to the right: GPU-Z shows 1408 shaders, BIOS in RBE shows the 6970 shaders box checked.
Considering that the success rate has been 80-90% for the reference style 6950's in the past, those are some pretty good odds right there. I also can't help but wonder whether Sapphire is specially buying cherry picked 6950 GPU's for this video card.
The success rate for non-reference Sapphire 6950s (not the Toxic) is like <20% based on what I've seen on various forums. This may be due to laser cutting of the shaders.
I should have clarified my post as yeah, I meant reference style 6950's and not the revised ones.
I had the power off, but not unplugged. I saved the stock BIOS, set the max oc to 950 and turned the shaders button to 6970 and I got a BSOD going into Windows. Flipped the switch back to stock and no problems. I will have to boot off of a USB key with ATIflash and flash the switched BIOS back to stock and play around with it some more.
Probably wont happen though, I won't see my dad's computer for awhile.
So it looks like they extended the MIR on newegg until 9/15 which makes me happy seeing as I haven't been able to grab a card yet. However, I'm not sure whether or not Deus Ex will be included still.
I JUST saw the same thing. It doesnt look like Deus Ex is included, however, which to me, at least, is a pretty big deal.
It's included with just about every other 6950, so I bet if you called them up and asked after placing the order, they would send you one.'
On another topic...
What's the deal with the "dual cooling fan" on the front of the box? Was that just an artwork SNAFU? 'Cuz the card's pretty clearly only got one fan.
I got Dirt3 with my Toxic 6950.
I keep missing these, and Newegg's auto notify feature seems to be broken.
Any helpful tips/ideas?
"Highest playable settings. Common sense would state that if a card performs exceptionally well at 2560x1600 it will perform even better at a lower resolution. If people are incapable of figuring that much out then they really shouldn't be building computers at all."
I think most of us know that AMD cards have an advantage at 2500x1600.
A gtx570 and 6970 will trade blows depending on the game at 1080p.
A 6970 will even best a gtx580 in a few games at 2500x1600 but a gtx580 will easily beat a 6970 @ 1080p.
A 6950 @ 2500x1600 will trade blows with a gtx570 in some games.
F5 F5 F5 F5 F5 F5 F5 if you want it that bad. Only way to do it.
First off, the review done by hardocp was so thorough, I joined the forum just because of that. Everything the guy says is true... I purchased my 6950 toxic...flipped the switch... 6970 shaders unlocked. Also the PCB is identical to the 6970 from sapphire...where as other 6950's are different from them. Changing the AMD overdrive to +25~ power gets me a 20% performance difference. Good job on the review..I saw many reviews for the card not noticing the power flux thing and saying how great the card was..when it was performing 20% under what it should.
^^b thanks for the review.
