I saw sapphire rx480 nitro is supplied with an 8 pin connector, but its priced at around 50€ more, do guyz think its worth it?
Also the two fans setup i think isnt as loud as default amd setting, so that also brings something to the table.
Is this for a 4gb or 8gb model?
If its the 8gb, note that you can get a 1060 for about $270, for a basic aftermarket card. And it will outpreform the 480 by quite a bit. Or downgrade to the RX 470, as others have said, since it preforms almost as good.
... i checked my store and basicly, i see the price is prity much the same around 300€, so if they will have long waiting time for rx480 i will just go for 1060 that is in stock.
I see tho 1060 doesnt support sli mode, which is a big downer, since i can pair two 480 and ride them into the sunset for decadesand getting 1080 performance for games that support crossfire.
Sorry but how has AMD not openly supported CF when they showcased it against the 1080 in their own presentation?As Madness said, if you're willing to buy two AMD GPUs based on the promise that EMA will kick off then the lack of SLI shouldn't bother you because the exact same thing will apply to the 1060.
In fact it's only NV who have openly committed to SLI support, AMD just keep playing the DX12/EMA card
That wasn't CF.Sorry but how has AMD not openly supported CF when they showcased it against the 1080 in their own presentation?
How do you mean that wasnt CF?That wasn't CF.
true and that is what i ment with longer lasting, but it doesnt matter, i found an alternative - 1070, which runs more stable fps.IIRC they used the 8pin on the Nitro so they could shift some of the power away from the PCIE connector, and give it more juice in general.
