Sapphire or Diamond 4870?
Mekanic01
That's all that's in stock at newegg, unless maybe somebody knows who has visionteks in stock. Which should I get, I want to make my order for my new system asap
I will never own another diamond product. they have a long history of discontinuing support for products, esp if there is a problem (edge 3D anyone?)
JM2C
JM2C
I thought the new Diamond is unrelated to the old company?
I don't know to be truthful. it would have been a hell of a name to pick up though. I thought they had just taken a break out of the graphic card market for about 7 years or so.
i loved my viper 770ultra!!
only if they would give a longer warranty then 1yr.. I'd pick them up in a heartbeat..
This is correct, another company now owns the Diamond name (Best Data). The original Diamond is now called SONICblue. (Diamond+S3).
Whether or not these new guys are better or not is unknown to me, i've heard very little about Diamond since them resurfacing.
What I can tell you from personal experience is Sapphire's RMA and Customer Service is pretty bad, i'd avoid that route if possible.
