Sapphire HD 6950 Re-Locked itself
Constantine769
Has anyone ever experienced this?
I successfully locked my Sapphire HD 6950 to 1536 Shaders a few months ago when I built my computer.
Today, I just checked it with a new version of GPU-Z 5.5 and it's showing 1408 Shaders.
The overlcock is holding at 880 / 1375 but the shaders changed.
Anyone know why?
Thanks
I don't wanna check mine... I don't want to know.
I wonder if the latest driver did it?
That doesn't make any sense, does you card have a bios switch? How did you unlock it? Did you use a 6970 bios or a unlocked 6950 bios?
Hmmmm . . . good question. MAYBE / HOPEFULLY / I WISH I bumped it while cleaning the inside.
What switch was it suppose to be again on? 1 or 2?
No way the latest drive can change it right since its a BIOS setting?
To the right or in other better words, away from the back plate of the card and toward the fan on the card.
