Sapphire card Issue.
realmatrix
I am using vga output.By default the screen postion @ 1360x768 is not centered on my TV.
My Lcd tv has native resolution of 1366x768. ati catalyst supports only 1360x768. hence to completely fill the screen I stretch the screen and move it to center and cover all 4 corners of the screen by force. (from screen adjustments in ati control panel).
I also switch between 1360x768 and 1024x768 quite often to run some games which don't have wide screen support.
Does doing so causes any harm ( as it alters the vertical and horizontal sync values) to the card because my previous card lasted only 2 months.
