Mar 22, 2004 #1 E eli [H]ard|Gawd Joined Apr 30, 2003 Messages 1,648 Does anyone know if the sapphire 9800 pro OEM version comes with the needed power supply cable? thanks
Mar 22, 2004 #2 S _Sin_ [H]ard|Gawd Joined Jan 1, 2003 Messages 1,652 it should, but usually a good power supply has plenty of extra molex connectors. otherwise you can buy a splitter cable for 2 bucks?
Mar 22, 2004 #4 E eli [H]ard|Gawd Joined Apr 30, 2003 Messages 1,648 ATI's do? this is a sapphire oem one.
Mar 22, 2004 #5 M Mikesta 2[H]4U Joined Jan 8, 2003 Messages 2,268 It should.. I was thinking about getting the one off of newegg.com for 214? or something.
Mar 22, 2004 #6 W WackDaddy Limp Gawd Joined Sep 8, 2002 Messages 253 Yes, mine came with a lengthy Y molex
