Sapphire 7970 374$
Voltage locked? I have the OC w/ Boost version of this (AKA Ghz Edition w/ Boost), but I only see it listing 925mhz stock clock.
Good price,
I just got one of these from amazon for 400 AR, and it's very nice :)
no idea if it is voltage locked. Some were, some are not. No idea if these are or not, most likely not, and if they are just do a bios flash.
its just the regular 7970, not the ghz edition.
Think it's worthwhile to jump on this and upgrade from an MSI TwinFrozr II 7950? Between resale of my 7950 and the games from the Never Settle Reloaded bundle, I'm thinking the upgrade would cost me less than $100 net.
This is not much of a step up if you have your 7950 well overclocked.
True.
Btw, this has dual bios, one of which is 1000/1450 or something as a minor upgrade.
I OCed mine to 1100/1550 in CCC and it runs great in xfire with my asus 7970.
At work at the moment, so I may not be 100% on this, but my 7950 is OCed at like 980/1475 at stock voltage. Anything higher than that and I start getting artifacts. I'm a novice when it comes to OCing, and very nervous about raising voltage in fear that I'll fry something.
I wouldn't bother wasting the $100 man..It's very easy to o/c these cards, and they can safely handle quite a bit of voltage..If you are worried (as you mentioned), just set it to 1.1~1.15V..That should get you over 1000-1025mhz or more on the core without a big increase in temps..
Just remember that when overclocking GDDR5, it is error correcting so you can clock it too high and assume it's stable when its really just downclocking itself..Get the max core o/c first, then slowly raise the memory in small steps while running a benchmark..once you reach the point where you aren't seeing any more performance increase, you are at the limit of the ram, so back it down a tiny bit and go play some games to test it out..
